:wave:
I've never used a machine polisher before and the paintwork on the Signum needs quite a bit of TLC.
I've borrowed a DAS-6 off a colleague and he's given me a couple of Menzerna polishes and a couple of pads with it.
Any tips for a newbie before I go and ruin my paintwork? :)
Don’t put a lot of pressure on it and don’t do the same but for too long or you’ll burn through the paint, and watch at ridges and edges as the paint is a bit thinner bud
Can't really damage the paint with a DA unless your really try.
B at advice is start with the least aggressive compound/ pad then see how you get on, my go to is chemguys v36 on a green or white hex logic pad, normally enough to get the minor swirls out but not agressive enough that it will need a finer compound finished over the top
Sent from my ONEPLUS 5T using Tapatalk
