I have a 1.9 CDTI Astra that's now done 100K. The gearbox bearings were replaced at about 45K and there is now a slight whine in 3rd and 4th gear when the car is not under load. When under load you can't hear the noise.
There is no movement of the gearstick in any gear although you can possibly feel the slightest of vibrations in 3rd and 4th if you hold the gearstick.
How many miles will it last before the gearbox goes pop?
The car isn't worth a vast amount and it's about to be retired from daily use and a another car will do the bulk of our miles however it would be useful to keep it as a spare car for tip runs and some winter use so going forward it'll only do 1K-2K miles a year.
Will the gearbox last a few years with that sort of mileage without the expense of a rebuild or does it rapidly go down hill?
Would an oil change now help extend it's life or is it too late for that? Presumably the damage is already done.
