Hi ... is it ok to fit Lowering Spring set (30mm drop) using standard Shockers? Car is Astra H 2009 SRI ... Cheers (y)
Yes a 30mm drop will be fine on standard shocks provided the are a good state usability? Also replace the top mounts a d probably do your drop links too. You could invest in a pair of cheap loly arb bushes up front too which will ad effect along with the springs 馃憤
Great ... thanks for your reply, will go ahead and order a set up 馃憤
