I have a 3 door Astra h that will soon be running the 18 inch pentas however I sent to keen on the gap between the wheel and the wheel arch so I was wondering if lowered would their be any clearance issues with full lock or the wheels rubbing on the arches ?
Lower it on eibach springs, I’ve got eibach prolines which drop it 30mm all around no rubbing issues at all and not much stiffer than standard, or you can go for eibach sportlines drops 50mm the front and 30mm at the rear, but rides harder and you may want to upgrade the shocks to vxr shocks, there shouldn’t be any rubbing issues at all with sportlines either as far as I know, but maybe someone with sportlines can comment
Dap-R are about the lowest springs you’ll get and retain a decent ride quality
