Locking Wheel Nut Help Please.
2K views 3 replies 2 participants last post by  valer
#1 ·
Good afternoon all, I hope this is the right place for this.
My middle son has a 2008 SRI that needs a new tyre, unfortunate he has lost the locking wheel nut key. It’s a four lobe pattern, does anyone live in or around Yeovil that might e kind enough to lend him one for a coupe of minutes please?
Obviously there will be a small renumeration for your troubles.
thanks.
#2 ·
If they are genuine GM locking bolts there are over 100 different patterns and many are quite similar,
we used to keep a master set for the workshop for the many cars that arrived with no locking key.
It would help narrow it down if you still have the key number
#4 ·
Yep that's the part number,the key number is on a small self adhesive bit of paper separate in the box,
you may struggle to find someone local with the same key,a good option is to have the bolt identified by photo ,
these can do that and supply a key
