Hi have LED headlamps on my 2009 1.6 worked great much better light tried to fit them in my 2006 1.4 and they will not work normal lights work fine LED ones just do not come on
Anyone else had this problem
Cheers
Dave
I had same problem got led with built in fans .I dont think they have a driver built in so probably need one to make them work
Easy fix people they need a resitor across the light terminals I loaded the LED lamp up with 2x21 + 1x5 w normal lamps and they now work fine calulated out need a 3 ohm resistor at about 50w so got 2x 3ohm 100w resistors coming
Also not to state the obvious please remember LED lamps are polarity sensitive on most lamps so you have to get them the correct way round
cheers
Dave
