selling my kicker L7 2ohm, this is an amazing sub and gives perfect bass every time, it has been looked after and not pushed and as you can see from the pictures it basically looks brand new, the sub is only about a month old so will come with the remainder of the warranty
i am only selling as i have given/sold my astra to my sister, and wont be buying a car for a few years as i'm at uni so a car really aint needed
specs:
12" L7 DUAL 2-OHM subwoofer (can be wired 1ohm or 4ohm)
Size (IN., CM): 12", 30cm
Square SoloKon™ polypropylene cone with Santoprene rubber surround
Sealed Box Volume (cu ft) 0.88-2.0
Ported Box Volume (cu ft) 1.75-3.25
Sensitivity 88.6dB
Frequency Response 20-100 Hz
RMS Power Range (Watts) 750
Peak Power Handling (Watts) 1500
Price
£225 O.N.O
selling my kicker L5 2ohm, this is an amazing sub and gives perfect bass every time, it has been looked after and not pushed and as you can see from the pictures it basically looks brand new
i am only selling due to getting a new subwoofer (the one i'm selling above), so sadly i have to sell this one.
specs:
12" Solo-Baric L5 Series Subwoofer
Power Handling: 1200 peak, 600 rs
the sub is 2ohm this means that you can either run it at 1ohm or 4ohm
currently the sub is wired to 1ohm
price
£70 without box
£110 with box
Lastly i have i have my crunch 1000 watt mono amp, also comes with a brand new wired control to turn the amp down
this amp can run at 1ohm stable and works perfect with both of the subs above and has never skipped a heart beat
Specs
Price
£100
the box is currently on the L7 but i can swap it to the L5 but their will be a chnage in price
package price:
L7 + box + Amp = £300
L5 = Box + amp = £250
only one grill so it will be sold with the first sub and box package sold unless its not wanted
all items are collection from coventry
or if you arrange your own courior i will package the items appropiatly
thanks for looking
specs:
Sensitivity 88.6dB
Price
£225 O.N.O
specs:
price
£70 without box
£110 with box
Specs
- PowerZone Series Monoblock Class AB Car Amplifier
- Peak (Dynamic) Power Rating:
- 4 ohms: 250 watts x 1 chan.
- 2 ohms: 500 watts x 1 chan.
- 1 ohm: 1000 watts x 1 chan.
- Max power output: 1000 watts x 1 chan.
- MOSFET power supply
- Wired remote bass level control included
- LED power and protect indicators
- Tuned Bass EQ (0-12 dB bass boost at 45 Hz)
- 1-ohm stable design
- Rugged MOSFET Audio Outputs
- Preamp RCA Output
- Overload, short, thermal, and DC protection
- Standard heatsink cooling
- Silver-coated RCA level inputs
- Variable mono low-pass filter (40-150 Hz, 24 dB/octave)
- Frequency response: 15-300 Hz
- Dimensions: 10"L x 16.53"W x 2.16"H
Price
£100
package price:
thanks for looking
