Im getting a new back box delivered tomorrow. is it a easy job to do yourself? it is a vauxhall part. would i need new rubber supports etc?
A.O.N. - Platinum Member
If you know what your doing then I would say yes,
You will need a jack + axle stands, some spanners, some WD40, the rubbers you should be able to take from the current backbox, You will need the gasket to join bacbox to the middle pipe, and dont forget your industrial size box of bad language :D
If you also have a camera, you could put a "how to" together for the other members on the site :D
