chaps
need help with the routing of cables (3 door astra h) going from battery to the boot. i have the power cable for my sub connected to the battery... coming through the rubber seal behind the glovebox....
my problem lies with conceling the wiring from here into the rear of the car.
i can pop off the door sill cable channel cover easy enough but the channel ends at the end of the front door....
i have a three door and i can figure out where im meant to hide the cabling.... i cant seem to get the rear seat plastic card off and cant figure out where to hide the cables. arghhhh
does this make sense?
can someone who has a three door astra h and has done the same thing explain what i need to do
cheers
A.O.N. - Platinum Member
You need a T50 torx bit to loosen the seatbelt bolt so you can lift the plastics to push the cables under
