This is a rough guide to add bluetooth capability to your CDR500 (and other opel radios). The VDA adapter exists in most -if not all- opel cars. I've installed this in several Astra-G and Zafira-A and I noticed that in some models the microphone cable is missing. In my car it was installed - the top end was tied somewhere behind the interior light cabling. Anyway from the following pictures you will get the general idea.
After the installation the operation is easy. When you get a call the radio is muted and the telephone sound is heard from the car speakers. The MID shows either 'message' or 'phone' depending on the display type.
What you need:
a. I used nokia bt units. Most bt units will do.
b. VDA adapter cabling loom. I got this from some German online shop. There are 2 types, simple and amplified. The simple is most of the time needed. The amplified works but might distort sound.
c. If the interior light has space for the opel microphone get one - but you can always use the included with the bt kit -either by modifying the plug to fit the cable installed at the car or by using the supplied cable.
d. A special transformer that is installed at the fuse box. This interfaces the sound from the bt to the car radio.
e. A 10A fuse
What you need:
e. A 10A fuse
