1 - 10 of 10 Posts
Hi
Thought I'd join her and post to help other people who have come across a similar problem.
This morning I drove to the petrol, filled up and the car would not start.
Turning the key, electrics seemed to be working, however the starter motor was not turning off/kicking in.
I did the pedal test, hold down accelerator and brake, turn ignition key 2 notches (3rd is actually starting the car), watch the flashing engine warning light, counting the number of flashes.
I saw the combination of 1614 flashes
I sat there Googling, could ECN, CIM
Check key fob battery
Locking, unlocking
In the end I called the RAC, who ran some tests with Machine and laptop
Battery Test
Drain Test
Starter Test
Alternator Test
The result was the battery needs replacing..
He got be started with a jumper kit, bought new battery for £45 and it's working fine (for now)
AON - Administrator
Welcome to AON
What car have you got? You've posted in the D,E,F section of the site but I assume from your post that you have a H?
What you describe is a common and well known problem and, as you have experienced, an easy fix.
Hi
It is my wife's car, it's a 54 plate, so I assume that it's a Mrk 5
Black 2004 Vauxhall Astra Club Twinport
Cheers I did a basic maths of 5 being E
The replacement Battery was a Sure Start 075 from a local shop (been there for year, very popular).
It looks like a generic (Japanese / Chinese) battery with a sticker on it.
It cost £45 (same price as cheapest online)
He gave me 2 years guarantee on it and he is local, so taking back should be easy, than return post.
Also as it's a is 12 years old car, I didn't think it warranted
Have you come across these before?
Was this a good or bad choice?
AON - Administrator
Never heard of them I'm afraid. It's stats are what is important, cca value, etc.
You've fallen in to that age old trap! In the UK the MK1 is a D, Mk2 is an E, etc. The A, B and C were only available as the Opel Kadett
1 - 10 of 10 Posts
