Hi the indicator stalk does not auto cancel when turning left,it does on right.I have purchased a new unit.How do i remove the shroud etc to remove the old one and fit the new one.Where are the screws etc and what do i need to remove.Appreciate as much detail as possible please.It is a Astra G hatchback 2002 Petrol !.4 16v.Thanks.I cannot find anything on goole or youtube
Hi Cleggy.
Took all apart about 6 or 7 years ago for an ECU change - I had to replace the immobiliser transponder ring around the ignition barrel as they're matched.
Only bit I remember is you have to remove the steering wheel rake / reach adjuster handle, just a screw I think. A few screws recessed within the housing, then the two halves split into top and bottom. Indicator stalk just slides out as I remember with plug on the back...? Memory's pretty faded on that though...
As I remember, when putting back together, worth pulling off the ignition barrel rubber surround as it easily gets missed and ends up the wrong side of the housing - then you have to take apart again!
Apologies if I've got anything wrong, it was a while ago. I don't remember it being a big deal though
See image below, you need to remove the two covers behind steering wheel - screws behind (turn wheel to expose) and one at bottom and rake handle remove. Easy
Related Threads
Astra Owners Network
2.8M posts
59.9K members
Since 2003
