Hey guys, wonder if you can help. I just cleaned out the inlet manifold on my Z16XEP 05 Astra H Twinport with carb cleaner, then reassembled. When I started, it's running way worse and spanner is on. Limp mode, no acceleration under load, revs ok stationary but no codes or EML.
Did I miss plugging something back in*? Possible I killed a sensor? MAF has no effect when removing. Starting to think I've ******* a sensor with the carb cleaner. Any pointers would be helpful as I was meant to be going to London tomorrow in it. Not happening now. Ta!
*I have a loose plug up behind the ECU on the same loom as the earth that goes to it, purple innerds, any idea what that is as it may be a clue...
