Discussion Starter #1 (Edited by Moderator)
My car randomly goes into limp mode for absolutely no reason. It is normally preceded by a slight loss of power however today I was able to pull over and conduct the pedal trick which gave me 3 codes of :
I have an Op-Com so I plugged in when I returned home and it told me the following :
112052 & 112252 appear to be the same and tell me it's accelerator pedal position sensor 1&2 signal incorrect ratio
50074 tells me it's vehicle speed signal range/performance
I'm guessing that all 3 are linked to the speed/performance of the accelerator but the question is how do I fix this????
AON - Administrator
Please don't copy and paste it makes your posts unreadable and they have to be edited (Y)
What engine is it?
Not wanting to sound like a clever **** but if you have error codes it would indicate that it isn't going in to limp for absolutely no reason.
