1.6 astra h showing fault codes 2182 and 1151 during pedal test does anyone have any idea what thes are as can’t find anything on internet
If it's a Z16XER, p2182 is a good code with 3 options,but P1151 doesn't come up for the same engine type so a bit confusing,best confirm the engine type and full ecn codes from the pedal test,
and don't forget unless you have a warning light on they may be historic.
P2182 14 Engine Coolant Temperature Sensor Open Or Short Circuit
P2182 13 Engine Coolant Temperature Sensor Circuit Low Voltage
P2182 17 Engine Coolant Temperature Sensor Circuit Range/Performance
I don’t have any warning light or anything however when my cars been on for a while and say I’m going through a drive through my fan will start making a really loud noise for about ten seconds is that normal on these cars
Yes the fan will kick in occasionally if it's been idling for a bit,
as for how noisy it is it's impossible to tell without hearing it although they can drone a bit.
