today the car just cut out on me in themiddle of the road took me 20 mins to get started again when i got home idone a pedal test and had these
ecn 007071
050074
213971
050071
33529
does anbody have and idea ov what these are am i right in thinking 33529 is crank shaft sensor.regards matthew.
Find below a list of Astra H Diesel fault codes by engine code.
Firstly either do the pedal test or use a diagnostic scanner to retrieve the code.
To do the pedal test, use the following instructions
Foot on the brake and the accellerator pedal
Key into the ignition and turn to position 2 (dash lights up but do not start the engine)
any stored error codes will be displayed as ECN Numbers in the tacho display.
Example: When the codes flash up they will show as ECN 112252. Remove the last two numbers as this is the sypmton number and replace the ECN with P. You will be left with P1122. Look down the list for the error code for your diesel engine.
P1122 Accelerator Pedal Position Sensor 2 High Input C-008
P1122 Accelerator Pedal Position Sensor 2 Low Input C-008
P1122 Accelerator Pedal Position Sensor 2 Range/Performance C-008
P1122 Accelerator Pedal Position Sensor 1 and 2 Signal Incorrect Ratio
Engine Codes Z19DT Z19DTJ Z19DTH
P0001 Fuel Metering Solenoid Valve Circuit High Voltage C-021
P0001 Fuel Metering Solenoid Valve Circuit Low Voltage C-021
P0001 Rail Pressure Low Pressure B-029
P0001 Rail Pressure High Pressure B-029
P0001 Fuel Metering Solenoid Valve Circuit Open C-021
P0001 Fuel Metering Solenoid Valve Powerstage High Temperature C-021
P0002 Rail Pressure Control Range/Performance B-029
P0002 Fuel Metering Solenoid Valve Circuit Range/Performance B-029
P0003 Fuel Metering Solenoid Valve Circuit Low Voltage C-021
P0004 Fuel Metering Solenoid Valve Circuit High Voltage C-021
P0016 Crankshaft/Camshaft Correlation B-018
P0030 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 1) C-029
P0030 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 1) B-025
P0030 O2 Sensor Heater Circuit Open (Bank 1 Sensor 1) B-025
P0030 O2 Sensor Heater Circuit Range/Performance (Bank 1 Sensor 1) B-030
P0030 O2 Sensor Heater Powerstage High Temperature (Bank 1 Sensor 1) C-029
P0070 Ambient Air Temperature Sensor Malfunction B-016
P0070 Ambient Air Temperature Low Input B-016
P0070 Ambient Air Temperature High Input B-016
P0087 Rail Pressure Low Pressure B-029
P0088 Rail Pressure High Pressure B-029
P0090 Rail Pressure Control Solenoid Valve Circuit Range/Performance (Negative Deviation) B-043
P0090 Rail Pressure Control Solenoid Valve Circuit Range/Performance (Positive Deviation) B-043
P0100 Mass Or Volume Air Flow Circuit High Input B-032
P0100 Mass Or Volume Air Flow Circuit Low Input B-028
P0100 Mass or Volume Air Flow Sensor Circuit Range/Performance B-037
P0100 Mass Or Volume Air Flow Circuit Malfunction C-012
P0100 Intake Air Temperature Sensor Circuit High Input C-013
P0100 Intake Air Temperature Sensor Circuit Low Input C-013
P0100 Intake Air Temperature Sensor Circuit Malfunction C-013
P0105 Boost Pressure Sensor Circuit High Input C-011
P0105 Boost Pressure Sensor Circuit Low Input C-011
P0105 Boost Pressure Sensor Circuit, Signal not plausible with Mass Air Flow Sensor C-011
P0105 Barometric Pressure not plausible with Boost Pressure B-047
P0110 Intake Air Temperature Sensor Circuit High Input C-014
P0110 Intake Air Temperature Sensor Circuit Low Input C-014
P0110 Intake Air Temperature Voltage High C-014
P0110 Intake Air Temperature Voltage Low C-014
P0110 Charge Air Temperature Sensor High Input C-014
P0110 Charge Air Temperature Sensor Low Input C-014
P0115 Engine Coolant Temperature Circuit High Input Engine Cooling C-001
P0115 Engine Coolant Temperature Sensor Circuit Range/Performance Engine Cooling C-001
P0115 Engine Coolant Temperature Circuit Low Input Engine Cooling C-001
P0115 Engine Coolant Temperature Incorrect Signal Engine Cooling C-001
P0115 Engine Coolant Temperature not Plausible with Engine Oil Temperature Engine Cooling C-001
P0130 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1) B-030
P0130 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1) B-030
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1) C-028
P0130 O2 Sensor - System Too Rich (Bank 1) B-030
P0130 O2 Sensor - System Too Lean (Bank 1) B-030
P0130 O2 Sensor Circuit (Bank 1 Sensor 1) C-001
P0130 O2 Sensor Circuit Range/Performance (Bank 1 Sensor 1) B-030
P0168 Fuel Reduction caused by High Fuel Temperature B-049
P0180 Fuel Temperature Sensor Circuit High Input C-015
P0180 Fuel Temperature Sensor Circuit Low Input C-015
P0190 Rail Pressure Sensor High Voltage C-020
P0190 Rail Pressure Sensor Low Voltage C-020
P0190 Rail Pressure Range/Performance C-020
P0201 Cylinder 1 Injector Circuit Low B-034
P0201 Cylinder 1 Injector Circuit Open B-034
P0201 Cylinder 1 Injector Short Circuit B-034
P0201 Cylinder 1 - Injector Circuit Malfunction B-034
P0202 Cylinder 2 Injector Circuit Low B-034
P0202 Cylinder 2 Injector Circuit Open B-034
P0202 Cylinder 2 Injector Short Circuit B-034
P0202 Cylinder 2 - Injector Circuit Malfunction B-034
P0203 Cylinder 3 Injector Circuit Low B-034
P0203 Cylinder 3 Injector Short Circuit B-034
P0203 Cylinder 3 Injector Circuit Open B-034
P0203 Cylinder 3 - Injector Circuit Malfunction B-034
P0204 Cylinder 4 Injector Circuit Low B-034
P0204 Cylinder 4 Injector Short Circuit B-034
P0204 Cylinder 4 Injector Circuit Open B-034
P0204 Cylinder 4 - Injector Circuit Malfunction B-034
P0217 Engine Overtemperature Condition Engine Cooling B-007
P0219 Engine Overspeed Condition C-009
P0230 Fuel Pump Primary Circuit High C-004
P0230 Fuel Pump Primary Circuit Low B-027
P0230 Fuel Pump Primary Circuit Open B-027
P0230 Fuel Pump Circuit High Temperature C-004
P0234 Boost Pressure Control Circuit Negative Deviation B-045
P0234 Boost Pressure Control Circuit Positive Deviation B-045
P0243 Boost Pressure Valve High Voltage C-016
P0243 Boost Pressure Valve Low Voltage B-021
P0243 Boost Pressure Valve Circuit Open B-021
P0243 Boost Pressure Valve Powerstage High Temperature C-016
P0262 Cylinder 1 Injector Circuit High C-023
P0265 Cylinder 2 Injector Circuit High C-024
P0268 Cylinder 3 Injector Circuit High C-025
P0271 Cylinder 4 Injector Circuit High C-026
P0335 Crankshaft Position Sensor "A" Circuit Range/Performance B-048
P0335 Crankshaft Position Sensor "A" Circuit Open C-009
P0340 Camshaft Position Sensor Circuit Open C-010
P0340 Camshaft Position Sensor Circuit Range/Performance B-018
P0380 Glow Device Circuit High Voltage C-033
P0380 Glow Device Circuit Low Voltage B-020
P0380 Glow Device Circuit Open Circuit C-033
P0380 Glow Device General Error C-033
P0380 Glow Device Powerstage High Temperature C-033
P0400 Exhaust Gas Recirculation Circuit High Voltage C-017
P0400 Exhaust Gas Recirculation Circuit Low Voltage B-023
P0400 Exhaust Gas Recirculation Circuit Open B-023
P0400 Exhaust Gas Recirculation Valve Powerstage High Temperature C-017
P0400 Exhaust Gas Recirculation Flow Excessive Detected B-044
P0400 Exhaust Gas Recirculation Flow Insufficient Detected B-036
P0425 Exhaust Gas Temperature Sensor High Voltage (Bank 1 Sensor 1) C-030
P0425 Exhaust Gas Temperature Sensor Low Voltage (Bank 1 Sensor 1) C-030
P0425 Exhaust Gas Temperature Sensor 1 High Temperature C-030
P0425 Exhaust Gas Temperature Sensor 1 Low Temperature C-030
P0425 Exhaust Gas Temperature Sensor 1 Temperature not Plausible C-030
P042A Exhaust Gas Temperature Sensor 2 High Voltage C-031
P042A Exhaust Gas Temperature Sensor 2 Low Voltage C-031
P042A Exhaust Gas Temperature Sensor 2 High Temperature C-031
P042A Exhaust Gas Temperature Sensor 2 Low Temperature C-031
P042A Exhaust Gas Temperature Sensor 1 + 2 not Plausible C-031
P0460 Fuel Level Sensor Circuit Range/Performance IPC (Instrument) B-013
P0500 Vehicle Speed Signal Range/Performance B-051
P0500 Vehicle Speed Sensor Circuit Incorrect Signal B-051
P0500 Vehicle Speed Signal Malfunction (CAN) B-051
P0500 Vehicle Speed Signal not plausible with Engine Speed and Injection Mass B-050
P0520 Engine Oil Pressure Sensor/Switch Circuit Open IPC (Instrument) C-018
P0530 A/C Pressure Sensor Circuit Low Input Heating, Ventilation and Air Conditioning System C-009
P0530 A/C Pressure Sensor Circuit High Input Heating, Ventilation and Air Conditioning System C-009
P0530 A/C Pressure Sensor Malfunction Heating, Ventilation and Air Conditioning System C-009
P0571 Brake Light Switch Circuit Incorrect Signal Exterior Lighting/Turn Indicator System B-014
P0571 Brake Light Switch Circuit High Input Exterior Lighting/Turn Indicator System B-014
P0571 Brake Light Switch Circuit Malfunction Exterior Lighting/Turn Indicator System B-014
P0620 Generator Lamp "L" Control Circuit Malfunction IPC (Instrument) C-021
P0621 Generator Lamp "L" Control Circuit Malfunction IPC (Instrument) C-021
P0622 Generator Field "F" Control Circuit Malfunction IPC (Instrument) C-021
P0638 Electronic Throttle Control High Voltage C-019
P0638 Electronic Throttle Control Low Voltage B-022
P0638 Electronic Throttle Control Circuit open B-022
P0638 Electronic Throttle Control Powerstage High Temperature C-019
P0641 5V Reference Circuit 1 High Voltage C-005
P0641 5V Reference Circuit 1 Low Voltage C-005
P0645 A/C Relay Voltage High Heating, Ventilation and Air Conditioning System B-017
P0645 A/C Relay Voltage Low Heating, Ventilation and Air Conditioning System B-017
P0645 A/C Relay Circuit Open Heating, Ventilation and Air Conditioning System B-017
P0645 A/C Relay Powerstage High Temperature Heating, Ventilation and Air Conditioning System B-017
P0651 5V Reference Circuit 2 High Voltage C-006
P0651 5V Reference Circuit 2 Low Voltage C-006
P0660 Swirl Level Control Solenoid Valve High Voltage C-018
P0660 Swirl Level Control Solenoid Valve Low Voltage B-024
P0660 Swirl Level Control Solenoid Valve Circuit Open B-024
P0660 Swirl Level Control Solenoid Powerstage High Temperature C-018
P0697 5V Reference Circuit 3 High Voltage C-007
P0697 5V Reference Circuit 3 Low Voltage C-007
P0700 Malfunction Indicator (MI) Request from Transmission Control Module (TCM) Range/Perform. AF 40-6 Electronic 6-Speed Automatic Transmission B-029
P0703 Brake Switch Circuit Malfunction Exterior Lighting/Turn Indicator System B-014
P0704 Clutch Switch Input Circuit Malfunction CRC (Electronic Cruise Control) B-010
P0960 Rail Pressure Control Solenoid Valve Circuit High Voltage C-022
P0960 Rail Pressure Control Solenoid Valve Circuit Low Voltage C-022
P0960 Rail Pressure Control Solenoid Valve Circuit Open C-022
P0960 Rail Pressure Control Solenoid Valve Powerstage High Temperature C-022
P0961 Rail Pressure Control Solenoid Valve Range/Performance C-022
P1105 Barometric Pressure Sensor Circuit High Input C-002
P1105 Barometric Pressure Sensor Circuit Low Input C-002
P1105 Barometric Pressure not plausible with Boost Pressure B-047
P1109 Swirl Actuator Malfunction B-033
P1109 Swirl Actuator Supply Voltage Range/Performance B-033
P1109 Swirl Actuator Feedback Circuit High Voltage B-033
P1109 Swirl Actuator Feedback Circuit Low Voltage B-033
P1109 Swirl Actuator Feedback Signal Malfunction B-033
P1109 Swirl Actuator Feedback Signal Range/Performance B-033
P1109 Swirl Actuator Feedback Powerstage High Temperature B-033
P1110 Swirl Actuator High Voltage C-018
P1110 Swirl Actuator Low Voltage B-024
P1110 Swirl Actuator Circuit Open B-024
P1110 Swirl Actuator Powerstage High Temperature C-018
P1120 Accelerator Pedal Position Sensor 1 High Input C-008
P1120 Accelerator Pedal Position Sensor 1 Low Input C-008
P1120 Accelerator Pedal Position Sensor 1 Range/Performance C-008
P1120 Accelerator Pedal Position Sensor 1 and 2 Signal Incorrect Ratio C-008
P1122 Accelerator Pedal Position Sensor 1 and 2 Signal Incorrect Ratio C-008
P1125 Throttle Actuator Supply Voltage Low Voltage C-019
P1125 Throttle Actuator Feedback Circuit Malfunction C-019
P1125 Throttle Actuator Malfunction C-019
P1125 Throttle Actuator Feedback Signal Range/Performance C-019
P1125 Throttle Actuator Feedback Powerstage High Temperature C-019
P1180 Fuel Filter Heater High Voltage C-035
P1180 Fuel Filter Heater Low Voltage B-019
P1180 Fuel Filter Heater Circuit Open C-035
P1180 Fuel Filter Heater Powerstage High Temperature C-035
P1481 Fan Control 1 Circuit High Voltage Engine Cooling B-004
P1481 Fan Control 1 Circuit Low Voltage Engine Cooling B-004
P1481 Fan Control 1 Circuit Open Engine Cooling C-003
P1481 Fan Control 1 Powerstage High Temperature Engine Cooling C-003
P1482 Fan Control 2 Circuit High Voltage Engine Cooling B-004
P1482 Fan Control 2 Circuit Low Voltage Engine Cooling B-004
P1482 Fan Control 2 Circuit Open Engine Cooling C-003
P1482 Fan Control 2 Powerstage High Temperature Engine Cooling C-003
P1483 Fan Control 3 Circuit High Voltage Engine Cooling B-004
P1483 Fan Control 3 Circuit Low Voltage Engine Cooling B-004
P1483 Fan Control 3 Circuit Open Engine Cooling C-003
P1483 Fan Control 3 Powerstage High Temperature Engine Cooling C-003
P1530 A/C Relay Voltage High Heating, Ventilation and Air Conditioning System B-017
P1530 A/C Relay Voltage Low Heating, Ventilation and Air Conditioning System B-017
P1530 A/C Relay Powerstage High Temperature Heating, Ventilation and Air Conditioning System B-017
P1530 A/C Relay Circuit Open Heating, Ventilation and Air Conditioning System B-017
P1560 System Voltage Malfunction Power Supply and Communication C-113
P1571 Brake Switch Circuit High Voltage Exterior Lighting/Turn Indicator System B-014
P1571 Brake Switch Circuit Malfunction Exterior Lighting/Turn Indicator System B-014
P1610 Immobiliser Function not Programmed Immobiliser B-015
P1610 Immobiliser Malfunction Immobiliser B-009
P1611 Wrong Security Code Entered Immobiliser B-015
P1613 Immobiliser No Or Wrong Signal Immobiliser B-008
P1614 Immobiliser Wrong Signal Received Immobiliser B-008
P1614 Wrong Transponder Key Immobiliser B-006
P1615 ECM (Engine Control Module) Identification Failed Immobiliser B-006
P1616 CIM (Steering Column Module) Wrong Environment Identifier Immobiliser B-006
P1625 Main Relay opens too early B-048
P1625 Main Relay opens too late C-003
P1700 Service Vehicle Soon Request from Transmission Control Module AF 40-6 Electronic 6-Speed Automatic Transmission B-029
P1810 Fuel-Injection Quantity Malfunction B-029
P1811 Torque Signal Malfunction (CAN) ABS/TC/ESP (Vehicle Dynamic System) B-018
P1813 Invalid Signal from TCM (Transmission Control Module) AF 40-6 Electronic 6-Speed Automatic Transmission B-029
P1815 Cruise Control Interface Malfunction CRC (Electronic Cruise Control) B-009
P1895 Limp home - Limited Performance B-049
P1900 Exhaust Gas Temperature Sensor (Bank 1 Sensor 1) not plausible with Intake Air Temperature C-030
P1900 Exhaust Gas Temperature Sensor (Bank 1 Sensor 2) not plausible with Intake Air Temperature C-031
P1900 Particulate Filter Regeneration Cycle Interrupted Several Times B-031
P1900 Exhaust Gas Temperature Sensor High Temperature (Bank 1 Sensor 1) C-030
P1900 Exhaust Gas Temperature Sensor Low Temperature (Bank 1 Sensor 1) C-030
P1900 Exhaust Gas Temperature Sensor High Temperature (Bank 1 Sensor 2) C-031
P1900 Exhaust Gas Temperature Sensor Low Temperature (Bank 1 Sensor 2) C-031
P1901 Particulate Filter Pressure Sensor High Voltage C-032
P1901 Particulate Filter Pressure Sensor Low Voltage C-032
P1901 Particulate Filter Pressure Sensor Hose Line Malfunction B-031
P1901 Particulate Filter Pressure Sensor High Differential Pressure B-031
P1901 Particulate Filter Pressure Sensor Low Differential Pressure B-031
P1901 Particulate Filter Pressure Sensor Pressure not Plausible with Barometric Pressure B-031
P1901 Particulate Filter Pressure Sensor High Pressure C-032
P1901 Particulate Filter Pressure Sensor Low Pressure B-031
P1902 Exhaust Gas Temperature Sensor High Voltage (Bank 1 Sensor 2) C-031
P1902 Exhaust Gas Temperature Sensor Low Voltage (Bank 1 Sensor 2) C-031
P2002 Particulate Filter Regeneration Not Completed B-031
P2075 Swirl Level Sensor Circuit Voltage Range/Performance B-024
P2075 Swirl Level Sensor Circuit Frequency Range/Performance C-018
P2075 Swirl Level Sensor Malfunction C-018
P2075 Swirl Level Sensor Circuit Open or High Voltage C-018
P2075 Swirl Level Sensor Circuit Low Voltage B-024
P2075 Swirl Level Sensor Circuit Range/Performance C-018
P2075 Swirl Level Control Solenoid Valve Stuck B-033
P2075 Swirl Level Control Solenoid Valve Frequency Range/Performance C-018
P2075 Swirl Level Control Solenoid Powerstage High Temperature C-018
P2146 Cylinder 1 + 4 Injector Circuit Voltage Range/Performance C-027
P2146 Cylinder 1 + 4 Injector Circuit Low Voltage C-027
P2146 Cylinder 1 + 4 Injector Circuit High Voltage C-027
P2146 Cylinder 1 + 4 Injector Circuit Open C-027
P2146 Injector 1 or 4 Circuit Open C-027
P2147 Injector 1 or 4 Short Circuit C-027
P2147 Injector 1 or 4 Malfunction C-027
P2149 Cylinder 2 + 3 Injector Circuit Voltage Range/Performance C-027
P2149 Cylinder 2 + 3 Injector Circuit Low Voltage C-027
P2149 Cylinder 2 + 3 Injector Circuit High Voltage C-027
P2149 Cylinder 2 + 3 Injector Circuit Open C-027
P2149 Injector 2 or 3 Circuit Open C-027
P2150 Injector 2 or 3 Short Circuit C-027
P2150 Injector 2 or 3 Malfunction C-027
P2226 Barometric Pressure Sensor Circuit High Input C-002
P2226 Barometric Pressure Sensor Circuit Low Input C-002
P2226 Barometric Pressure Sensor Circuit Malfunction C-002
P2226 Barometric Pressure Sensor Range/Performance C-002
P2237 O2 Sensor Pump Current Circuit High Voltage (Bank 1 Sensor 1) C-028
P2237 O2 Sensor Pump Current Circuit Low Voltage (Bank 1 Sensor 1) C-028
P2237 O2 Sensor Pump Current Circuit Open (Bank 1 Sensor 1) C-028
P2244 O2 Sensor Reference Cell Circuit High Voltage (Bank 1 Sensor 1) C-028
P2244 O2 Sensor Reference Cell Circuit Low Voltage (Bank 1 Sensor 1) C-028
P2244 O2 Sensor Reference Cell Circuit Open (Bank 1 Sensor 1) C-028
P2251 O2 Sensor Ground Circuit High Voltage (Bank 1 Sensor 1) C-028
P2251 O2 Sensor Ground Circuit Low Voltage (Bank 1 Sensor 1) C-028
P2251 O2 Sensor Ground Circuit Open (Bank 1 Sensor 1) C-028
P2264 "Water In Fuel" Sensor Circuit Malfunction B-017
P2279 Intake Air System Leak Detected B-035
P242F Particulate Filter Pressure Sensor Range/Performance B-031
P2452 Particulate Filter Pressure Sensor High Voltage C-032
P2452 Particulate Filter Pressure Sensor Low Voltage C-032
P2452 Particulate Filter Pressure Sensor Pressure not Plausible with Barometric Pressure B-031
P2452 Particulate Filter Pressure Sensor Hose Line Malfunction B-031
U2139 Invalid Signal from CIM (Steering Column Module) C-001
Z17DTL Z17 DTH
P0001 Fuel Metering Solenoid Valve Circuit Open C-017
P0001 Fuel Metering Solenoid Valve Powerstage High Temperature C-017
P0002 Fuel Metering Solenoid Valve Circuit Range/Performance B-027
P0003 Fuel Metering Solenoid Valve Circuit Low Voltage C-017
P0004 Fuel Metering Solenoid Valve Circuit High Voltage C-017
P0016 Crankshaft/Camshaft Correlation B-032
P0070 Ambient Air Temperature Sensor Malfunction B-017
P0087 Rail Pressure Low Pressure B-027
P0088 Rail Pressure High Pressure B-027
P0100 Mass Or Volume Air Flow Circuit Malfunction C-011
P0100 Mass Or Volume Air Flow Circuit High Input B-020
P0100 Mass Or Volume Air Flow Circuit Low Input B-020
P0100 Mass or Volume Air Flow Sensor Circuit Range/Performance C-011
P0100 Intake Air Temperature Sensor Circuit Low Input C-010
P0100 Intake Air Temperature Sensor Circuit High Input C-010
P0100 Intake Air Temperature Sensor Circuit Malfunction C-010
P0105 Boost Pressure Sensor Circuit Low Input C-012
P0105 Boost Pressure Sensor Circuit High Input C-012
P0105 Barometric Pressure not plausible with Boost Pressure B-025
P0115 Engine Coolant Temperature Circuit Low Input Engine Cooling B-010
P0115 Engine Coolant Temperature Circuit High Input Engine Cooling B-010
P0115 Engine Coolant Temperature Sensor Circuit Range/Performance Engine Cooling B-010
P0190 Rail Pressure Sensor Low Voltage C-016
P0190 Rail Pressure Sensor High Voltage C-016
P0201 Cylinder 1 Injector Circuit Open C-019
P0202 Cylinder 2 Injector Circuit Open C-020
P0203 Cylinder 3 Injector Circuit Open C-021
P0204 Cylinder 4 Injector Circuit Open C-022
P0219 Engine Overspeed Condition C-007
P0234 Boost Pressure Control Circuit Negative Deviation B-021
P0234 Boost Pressure Control Circuit Positive Deviation B-021
P0243 Boost Pressure Valve High Voltage C-013
P0243 Boost Pressure Valve Low Voltage C-013
P0243 Boost Pressure Valve Circuit Open C-013
P0243 Boost Pressure Valve Powerstage High Temperature C-013
P0262 Cylinder 1 Injector Circuit High C-019
P0265 Cylinder 2 Injector Circuit High C-020
P0268 Cylinder 3 Injector Circuit High C-021
P0271 Cylinder 4 Injector Circuit High C-022
P0335 Crankshaft Position Sensor "A" Circuit Range/Performance C-007
P0335 Crankshaft Position Sensor "A" Circuit Open C-007
P0340 Camshaft Position Sensor Circuit Range/Performance C-008
P0340 Camshaft Position Sensor Circuit Open C-008
P0380 Glow Device Circuit High Voltage B-035
P0380 Glow Device Circuit Low Voltage B-035
P0380 Glow Device Circuit Open Circuit B-035
P0380 Glow Device General Error B-035
P0380 Glow Device Powerstage High Temperature C-025
P0400 Exhaust Gas Recirculation Circuit High Voltage B-033
P0400 Exhaust Gas Recirculation Circuit Low Voltage B-033
P0400 Exhaust Gas Recirculation Circuit Open B-033
P0400 Exhaust Gas Recirculation Flow Insufficient Detected B-030
P0400 Exhaust Gas Recirculation Flow Excessive Detected B-030
P0400 Exhaust Gas Recirculation Valve Powerstage High Temperature C-023
P0500 Vehicle Speed Signal not plausible with Engine Speed and Injection Mass B-031
P0500 Vehicle Speed Signal Range/Performance ABS/TC/ESP (Vehicle Dynamic System) B-011
P0622 Generator Field "F" Control Circuit Malfunction C-030
P0638 Electronic Throttle Control High Voltage C-014
P0638 Electronic Throttle Control Low Voltage C-014
P0638 Electronic Throttle Control Circuit open C-014
P0638 Electronic Throttle Control Powerstage High Temperature C-014
P0641 5V Reference Circuit 1 Low Voltage C-004
P0641 5V Reference Circuit 1 High Voltage C-004
P0651 5V Reference Circuit 2 Low Voltage C-005
P0651 5V Reference Circuit 2 High Voltage C-005
P0697 5V Reference Circuit 3 Low Voltage C-006
P0697 5V Reference Circuit 3 High Voltage C-006
P1105 Barometric Pressure Sensor Circuit Low Input C-001
P1105 Barometric Pressure Sensor Circuit High Input C-001
P1110 Swirl Actuator High Voltage B-034
P1110 Swirl Actuator Low Voltage B-034
P1110 Swirl Actuator Circuit Open B-034
P1110 Swirl Actuator Powerstage High Temperature C-015
P1120 Accelerator Pedal Position Sensor 1 High Input C-009
P1120 Accelerator Pedal Position Sensor 1 Range/Performance C-009
P1120 Accelerator Pedal Position Sensor 1 and 2 Signal Incorrect Ratio C-009
P1122 Accelerator Pedal Position Sensor 2 High Input C-009
P1122 Accelerator Pedal Position Sensor 2 Range/Performance C-009
P1122 Accelerator Pedal Position Sensor 1 and 2 Signal Incorrect Ratio C-009
P1125 Throttle Actuator Feedback Signal Range/Performance C-014
P1180 Fuel Filter Heater High Voltage C-026
P1180 Fuel Filter Heater Low Voltage B-036
P1180 Fuel Filter Heater Circuit Open B-036
P1180 Fuel Filter Heater Powerstage High Temperature C-026
P1400 Exhaust Gas Recirculation Circuit Low Voltage C-024
P1400 Exhaust Gas Recirculation Circuit High Voltage C-024
P1400 Exhaust Gas Recirculation Circuit Range/Performance C-024
P1400 Exhaust Gas Recirculation Valve Stuck C-024
P1481 Fan Control 1 Circuit Open Engine Cooling B-004
P1481 Fan Control 1 Powerstage High Temperature Engine Cooling B-004
P1482 Fan Control 2 Circuit Open Engine Cooling B-004
P1482 Fan Control 2 Powerstage High Temperature Engine Cooling B-004
P1483 Fan Control 3 Circuit Open Engine Cooling B-004
P1483 Fan Control 3 Powerstage High Temperature Engine Cooling B-004
P1610 Immobiliser Function not Programmed Immobiliser B-009
P1625 Main Relay opens too early B-016
P1815 Cruise Control Interface Malfunction CRC (Electronic Cruise Control) B-008
P1895 Limp home - Limited Performance B-013
P2147 Injector 1 or 4 Short Circuit C-018
P2147 Injector 1 or 4 Malfunction C-018
P2150 Injector 2 or 3 Short Circuit C-018
P2150 Injector 2 or 3 Malfunction C-018
P2279 Intake Air System Leak Detected B-019
Z13DTH
P0030 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 1) C-027
P0030 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 1) B-042
P0070 Ambient Air Temperature Sensor Malfunction B-020
P0088 Rail Pressure High Pressure B-047
P0090 Rail Pressure Control Valve Voltage High C-022
P0090 Rail Pressure Control Valve Voltage Low C-022
P0093 High Pressure Diagnosis Malfunction C-022
P0095 Charge Air Temperature Sensor Low Input C-015
P0095 Charge Air Temperature Sensor High Input C-015
P0095 Charge Air Temperature Sensor Malfunction B-053
P0100 Mass Air Flow Sensor Voltage Low B-043
P0100 Mass Air Flow Sensor Circuit Low Input B-043
P0100 Mass Air Flow Sensor Voltage High B-024
P0100 Mass Air Flow Sensor Circuit High Input B-025
P0106 Barometric Pressure not plausible with Boost Pressure B-031
P0107 Boost Pressure Low Pressure B-027
P0108 Boost Pressure High Pressure B-028
P0110 Intake Air Temperature Sensor Circuit Malfunction B-052
P0130 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1) C-028
P0130 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1) C-028
P0130 O2 Sensor Circuit Range/Performance (Bank 1 Sensor 1) C-028
P0135 O2 Sensor Heater Circuit Range/Performance (Bank 1 Sensor 1) B-050
P0168 Fuel Reduction caused by High Fuel Temperature B-032
P0180 Fuel Temperature Sensor Circuit Low Input C-016
P0180 Fuel Temperature Sensor Circuit High Input C-016
P0180 Fuel Temperature Sensor Circuit Malfunction B-054
P0190 Rail Pressure Sensor Low Input C-020
P0190 Rail Pressure Sensor High Input C-020
P0190 Rail Pressure Range/Performance (Negative Deviation) C-020
P0190 Rail Pressure Range/Performance (Positive Deviation) C-020
P0201 Cylinder 1 Injector Circuit High C-023
P0201 Cylinder 1 Injector Circuit Low C-023
P0201 Cylinder 1 Injector Circuit Open C-023
P0201 Cylinder 1 Injector Malfunction C-023
P0202 Cylinder 2 Injector Circuit High C-024
P0202 Cylinder 2 Injector Circuit Low C-024
P0202 Cylinder 2 Injector Circuit Open C-024
P0202 Cylinder 2 Injector Malfunction C-024
P0203 Cylinder 3 Injector Circuit High C-025
P0203 Cylinder 3 Injector Circuit Low C-025
P0203 Cylinder 3 Injector Circuit Open C-025
P0203 Cylinder 3 Injector Malfunction C-025
P0204 Cylinder 4 Injector Circuit High C-026
P0204 Cylinder 4 Injector Circuit Low C-026
P0204 Cylinder 4 Injector Circuit Open C-026
P0204 Cylinder 4 Injector Malfunction C-026
P0217 Fuel Reduction caused by High Coolant Temperature B-032
P0219 Engine Overspeed Condition C-008
P0230 Fuel Pump Relay Voltage Low C-004
P0230 Fuel Pump Relay Voltage High C-004
P0235 Boost Pressure Sensor Circuit High Input C-012
P0235 Boost Pressure Sensor Circuit Low Input C-012
P0243 Boost Pressure Valve High Voltage C-017
P0243 Boost Pressure Valve Low Voltage B-039
P0243 Boost Pressure Valve Circuit Open B-039
P0243 Boost Pressure Control Circuit Negative Deviation B-055
P0243 Boost Pressure Control Circuit Positive Deviation B-055
P0335 Crankshaft Sensor Circuit Range/Performance C-008
P0340 Camshaft Position Sensor Circuit Low Input C-009
P0340 Camshaft Position Sensor Circuit High Input C-009
P0340 Camshaft Position Sensor Circuit Range/Performance C-009
P0380 Glow Device Circuit High Voltage C-032
P0380 Glow Device Circuit Low Voltage B-038
P0380 Glow Device Circuit Open Circuit B-038
P0400 Exhaust Gas Recirculation Valve Malfunction B-051
P0400 Exhaust Gas Recirculation Valve Stuck B-051
P0403 Exhaust Gas Recirculation Circuit Low Voltage C-018
P0403 Exhaust Gas Recirculation Circuit High Voltage C-018
P0403 Exhaust Gas Recirculation Circuit Open C-018
P0500 Vehicle Speed Signal Range/Performance B-030
P0520 Engine Oil Pressure Sensor/Switch Circuit Low Voltage IPC (Instrument) C-018
P0520 Engine Oil Pressure Sensor/Switch Circuit High Voltage IPC (Instrument) C-018
P0565 Cruise Control Switch Malfunction CRC (Electronic Cruise Control) B-006
P0571 Brake Light Switch Circuit Low Input Exterior Lighting/Turn Indicator System B-014
P0622 Generator Field "F" Control Circuit Malfunction B-057
P0638 Electronic Throttle Control Low Voltage B-040
P0638 Electronic Throttle Control Circuit open B-040
P0683 Glow Plug Circuit Low Voltage B-038
P0683 Glow Plug Circuit Open B-038
P0685 Main Relay Circuit High Voltage C-003
P0685 Main Relay Circuit Low Voltage C-003
P0700 Malfunction Indicator (MI) Request from Transmission Control Module (TCM) Range/Perform. MTA (Easytronic) (M20-6MTA/M32-6MTA) B-025
P1088 Rail Pressure High Pressure B-048
P1093 Fuel System Malfunction C-022
P1105 Barometric Pressure Sensor Circuit Low Input C-011
P1105 Barometric Pressure Sensor Circuit High Input C-011
P1120 Accelerator Pedal Position Sensor 1 High Input C-010
P1120 Accelerator Pedal Position Sensor 1 Low Input C-010
P1120 Accelerator Pedal Position Sensor 1 Malfunction C-010
P1120 Accelerator Pedal Position Sensor 1 and 2 Signal Incorrect Ratio C-010
P1122 Accelerator Pedal Position Sensor 2 Low Input C-010
P1122 Accelerator Pedal Position Sensor 2 High Input C-010
P1122 Accelerator Pedal Position Sensor 2 Malfunction C-010
P1180 Fuel Filter Heater High Voltage C-034
P1180 Fuel Filter Heater Low Voltage B-037
P1180 Fuel Filter Heater Circuit Open B-037
P1190 Rail Pressure Control Valve Stuck B-047
P1191 Fuel Metering Solenoid Valve Circuit Range/Performance B-048
P1191 Rail Pressure Range/Performance B-049
P1191 Rail Pressure Low Pressure B-049
P1192 Rail Pressure High Pressure B-049
P1264 Water in Fuel Filter Detected B-021
P1564 Battery Circuit Open C-039
P1571 Brake Switch Circuit Low Voltage Exterior Lighting/Turn Indicator System B-014
P1619 Airbag Deployed SDM (Airbag) B-008
P1620 5V Reference Circuit 1 High Voltage C-005
P1620 5V Reference Circuit 1 Low Voltage C-005
P1625 Main Relay Output Voltage Low B-017
P1625 Main Relay Output Voltage High B-017
P1635 5V Reference Circuit 2 High Voltage C-006
P1635 5V Reference Circuit 2 Low Voltage C-006
P1639 5V Reference Circuit 3 Low Voltage C-007
P1639 5V Reference Circuit 3 High Voltage C-007
P1700 Service Vehicle Soon Request from Transmission Control Module MTA (Easytronic) (M20-6MTA/M32-6MTA) B-025
P1814 Invalid Signal from ECC (Electronic Climate Control) ECC/SAC (Electronic Climate Control) C-003
P1900 Limp Home - Particulate Filter Limited Performance B-046
P1900 Particulate Filter Regeneration Cycle Interrupted Several Times B-056
P1901 Particulate Filter Pressure Sensor Low Voltage C-030
P1901 Particulate Filter Pressure Sensor Low Differential Pressure C-030
P1901 Particulate Filter Pressure Sensor High Differential Pressure B-056
P1901 Particulate Filter Pressure Sensor High Voltage C-030
P1901 Particulate Filter Pressure Sensor Range/Performance B-056
P1901 Particulate Filter Differential Pressure Signal not Plausible with Mass Air Flow C-030
P1901 Particulate Filter Pressure Sensor Hose Line Malfunction C-030
P1902 Exhaust Gas Temperature Sensor Circuit Low Voltage C-029
P1902 Exhaust Gas Temperature Sensor Circuit Open or High Voltage C-029
P1902 Exhaust Gas Temperature Sensor Signal Range/Performance C-029
P2003 Particulate Filter Pressure Sensor Much too High Differential Pressure C-030
P2146 Capacitor Voltage 1 High Voltage C-001
P2146 Capacitor Voltage 1 Low Voltage C-001
P2237 O2 Sensor Pump Current Circuit Malfunction (Bank 1 Sensor 1) C-028
P2244 O2 Sensor Reference Cell Circuit Malfunction (Bank 1 Sensor 1) C-028
P2264 "Water In Fuel" Sensor Circuit Malfunction B-021
P2297 O2 Sensor Circuit Range/Performance (Bank 1 Sensor 1) B-050
U2106 Invalid Data from TCM (Transmission Control Module) MTA (Easytronic) (F13-5MTA/F17-5MTA) B-029
U2108 Invalid Data from ABS (Anti-Lock Brake System) ABS/TC/ESP (Vehicle Dynamic System) B-018
Z17DTR Z17DTJ A17DTJ A17DTR
P0001 Fuel Metering Solenoid Valve Circuit High Voltage C-018
P0001 Fuel Metering Solenoid Valve Circuit Low Voltage C-018
P0001 Fuel Metering Solenoid Valve Stuck B-025
P0016 Crankshaft/Camshaft Correlation B-015
P0030 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) B-024
P0030 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1) B-024
P0087 Rail Pressure Low Pressure B-025
P0088 Rail Pressure High Pressure B-025
P0093 Rail Pressure High Pressure B-025
P0094 Rail Pressure Range/Performance B-025
P0095 Charge Air Temperature Sensor High Input C-012
P0095 Charge Air Temperature Sensor Low Input C-012
P0100 Mass Or Volume Air Flow Circuit High Input B-021
P0100 Mass Or Volume Air Flow Circuit Low Input B-021
P0100 Mass or Volume Air Flow Sensor Circuit Range/Performance B-021
P0110 Intake Air Temperature Sensor Circuit High Input C-011
P0110 Intake Air Temperature Sensor Circuit Low Input C-011
P0110 Intake Air Temperature Sensor Circuit High Frequency C-011
P0110 Intake Air Temperature Sensor Circuit Low Frequency C-011
P0130 O2 Sensor Ground Circuit High Voltage (Bank 1 Sensor 1) C-028
P0130 O2 Sensor Ground Circuit Low Voltage (Bank 1 Sensor 1) C-028
P0130 O2 Sensor Pump Current Circuit High Voltage (Bank 1 Sensor 1) C-028
P0130 O2 Sensor Pump Current Circuit Low Voltage (Bank 1 Sensor 1) C-028
P0168 Fuel Quantity Reduction caused by High Exhaust Gas Temperature B-034
P0180 Fuel Temperature Sensor Circuit High Input C-013
P0180 Fuel Temperature Sensor Circuit Low Input C-013
P0190 Rail Pressure Sensor High Voltage C-006
P0190 Rail Pressure Sensor Low Voltage C-006
P0190 Rail Pressure Range/Performance C-006
P0190 Rail Pressure High Pressure C-006
P0217 Engine Overtemperature Condition Engine Cooling B-008
P0234 Boost Pressure High Pressure B-036
P0235 Boost Pressure Sensor Circuit High Input C-009
P0235 Boost Pressure Sensor Circuit Low Input C-009
P0235 Boost Pressure Sensor Circuit Range/Performance C-009
P0243 Boost Pressure Valve High Voltage B-019
P0243 Boost Pressure Valve Low Voltage B-019
P0299 Boost Pressure Low Pressure B-036
P0299 Intake Air System Leak Detected B-036
P0301 Cylinder 1 Misfire Detected C-019
P0302 Cylinder 2 Misfire Detected C-020
P0303 Cylinder 3 Misfire Detected C-021
P0304 Cylinder 4 Misfire Detected C-022
P0335 Crankshaft Position Sensor Signal Range/Performance C-007
P0335 Crankshaft Position Sensor Circuit Malfunction C-007
P0340 Camshaft Position Sensor Circuit Malfunction C-008
P0380 Glow Device Circuit High Voltage B-016
P0380 Glow Device Circuit Low Voltage B-016
P0400 Exhaust Gas Recirculation Valve Stuck C-015
P0400 Exhaust Gas Recirculation Flow Excessive Detected C-015
P0403 Exhaust Gas Recirculation Circuit Open C-015
P0403 Exhaust Gas Recirculation Circuit Low Voltage or High Voltage C-015
P0409 Exhaust Gas Recirculation (EGR) Valve Feedback Voltage High C-015
P0409 Exhaust Gas Recirculation (EGR) Valve Feedback Voltage Low C-015
P0409 Exhaust Gas Recirculation (EGR) Valve Feedback Incorrect Signal C-015
P0425 Exhaust Gas Temperature Sensor 1 High Voltage C-025
P0425 Exhaust Gas Temperature Sensor 1 Low Voltage C-025
P0425 Exhaust Gas Temperature Sensor 1 High Temperature C-025
P0425 Exhaust Gas Temperature Sensor 1 Temperature not Plausible B-028
P042A Exhaust Gas Temperature Sensor 2 High Voltage C-026
P042A Exhaust Gas Temperature Sensor 2 Low Voltage C-026
P042A Exhaust Gas Temperature Sensor 2 High Temperature C-026
P042A Exhaust Gas Temp. Sen. 2 not Plausible with Exhaust Gas Temp. Sen. 1 and Intake Air Temp. B-029
P0480 Fan Control 1 Circuit High Voltage Engine Cooling B-005
P0480 Fan Control 1 Circuit Low Voltage Engine Cooling B-005
P0481 Fan Control 2 Circuit High Voltage Engine Cooling B-005
P0481 Fan Control 2 Circuit Low Voltage Engine Cooling B-005
P0482 Fan Control 3 Circuit High Voltage Engine Cooling B-005
P0482 Fan Control 3 Circuit Low Voltage Engine Cooling B-005
P0500 Vehicle Speed Sensor Malfunction ABS/TC/ESP (Vehicle Dynamic System) B-010
P0520 Engine Oil Pressure Sensor/Switch Circuit Range/Performance IPC (Instrument) C-018
P0530 A/C Pressure Sensor Circuit Open Heating, Ventilation and Air Conditioning System C-009
P0571 Brake Light Switch Permanently Active Exterior Lighting/Turn Indicator System B-014
P0615 Starter Relay Circuit High Voltage B-023
P0615 Starter Relay Circuit Low Voltage B-023
P0638 Throttle Control Solenoid Valve High Voltage B-017
P0638 Throttle Control Solenoid Valve Low Voltage B-017
P0641 5V Reference Circuit 1 High Voltage C-003
P0641 5V Reference Circuit 1 Low Voltage C-003
P0651 5V Reference Circuit 2 High Voltage C-004
P0651 5V Reference Circuit 2 Low Voltage C-004
P0660 Swirl Level Control Solenoid Valve High Voltage B-018
P0660 Swirl Level Control Solenoid Valve Low Voltage B-018
P0683 Glow Device General Error B-016
P0685 Main Relay Circuit High Voltage C-002
P0685 Main Relay Stuck Closed C-002
P0704 Clutch Switch Input Circuit Malfunction CRC (Electronic Cruise Control) B-011
P1120 Accelerator Pedal Position Sensor 1 High Input C-005
P1120 Accelerator Pedal Position Sensor 1 Low Input C-005
P1120 Accelerator Pedal Position Sensor 1 and 2 Signal Incorrect Ratio C-005
P1122 Accelerator Pedal Position Sensor 2 High Input C-005
P1122 Accelerator Pedal Position Sensor 2 Low Input C-005
P1571 Brake Light Switch Circuit Malfunction Exterior Lighting/Turn Indicator System B-014
P1625 Main Relay Circuit Low Voltage B-020
P1625 Main Relay Stuck Open B-020
P2002 Particulate Filter Regeneration Not Completed B-037
P2146 Cylinder 1 + 4 Injector Circuit Low Voltage C-023
P2146 Cylinder 1 + 4 Injector Circuit High Voltage C-023
P2149 Cylinder 2 + 3 Injector Circuit Low Voltage C-023
P2149 Cylinder 2 + 3 Injector Circuit High Voltage C-023
P2226 Barometric Pressure Sensor Circuit Low Input C-001
P2226 Barometric Pressure Sensor Circuit High Input C-001
P2425 Exhaust Gas Recirculation Cooler Bypass Solenoid Valve Circuit High Voltage B-022
P2425 Exhaust Gas Recirculation Cooler Bypass Solenoid Valve Circuit Low Voltage B-022
P242F Diesel Particulate Filter Overloaded C-027
P2452 Particulate Filter Pressure Sensor High Voltage B-026
P2452 Particulate Filter Pressure Sensor Low Voltage B-026
P2452 Particulate Filter Differential Pressure Signal not Plausible with Mass Air Flow B-026
P2452 Particulate Filter Pressure Sensor Hose Line Malfunction B-026
P2452 Particulate Filter Pressure Sensor High Pressure B-026
P2620 Throttle Control Malfunction C-017
U0405 Cruise Control Interface Malfunction CRC (Electronic Cruise Control) B-009
