hi all my astra van is really begining to do my head in now! Basically the clutch was dragging and was difficult to get into gear on inspection it was the wrong f23 box so tonight i put another box on the correct one tis time only to have the same problem both my mechanic and i are mega confuse someone must know something please
Has the vehicle got the right flywheel and clutch fitted?
At some point, Vx started fitting DMF's to the 2.0DTi. A difference in depth between the standard flywheel and DMF could be causing a problem.
Also, have you checked the clutch master cylinder - perhaps a problem with that is stopping the clutch from fully disengaging? :dontknow:
It feels like its not engaging properly I've replaced the csc and the clutch plate looks in mint condition I'm in sure of the fly wheel but if it is the wrong one would this stop it from engaging? I've borrowed the ramps twice now so fingers crossed 3rd time lucky!
