Hi,
On way home this evening was driving up a bit of a hill and went to accelerate up it but had lack of power then the engine management light come on.
Got home and performed the pedal test with the following results
161450
161600
046071
030101
030201
030301
030401
My car is a 2004 Astra h 1.8
Ignore the first two, the last four are telling you about the misfire on cyls 1,2,3,and 4.
Probably the coil pack, but interesting as to what P0460 is doing in there.
If you've got a normal 16V 1.8 then that relates to the fuel level signal going to the instruments, if it's a VVT then it's just the IPC telling the ECU it can't see the REC.
So a new coil pack will sort out the the 4 faults, and how do I rectify the one with the fuel signal fault
Coil pack and plugs is a good starting point for any misfire.
The problem with the pedal test is the codes it produces might not all be current so that odd code might be relevant and it might not. Which engone do you have? If it's a VVT then I wouldn't worry about any canbus comms codes unless you get any further issues.
Sent using Tapatalk just as it should be and not the AG app.
