1 - 20 of 21 Posts
My car is a 2015 astra j 1.6 with 75k miles on the clock and when doing the oil check and i noticed black gunk in the expansion tank car starts and drives fine but is loosing coolant but is no coolant leaks thanks
Oil cooler is the number one suspect
Discussion Starter · #8 ·
Hi i have changed the oil cooler gave it a couple of flushes and changed the expansion tank and it was clear for a bit but now has come back changed the seals to dont know what to do at this point
Hi sorry for not updating yet car overheated today and I think it has caused the head gasket to blow how can I tell
You would have to get it pressure tested or you can buy a combustion leak kick on Amazon (blue liquid that tests for combustion gases). Ideally do both.
Sent from my moto g(8) plus using Tapatalk
Discussion Starter · #12 ·
How much are these
One very quick Google.
There is a different type on Amazon which is more expensive £45 but I've tried and tested this s one and it does work, cannot voucher for the accuracy of the eBay one
Discussion Starter · #15 ·
Is there all ways going to be exhaust gases in the coolant bottle
Discussion Starter · #17 ·
You will need to let it get up to temperature some, if unsure how to use it, YouTube search Bodgit and leggit garage - headgasket, in one of his videos he tests the device
Will I be able to see bubbles in the tank if it is bubbling wont i be able to smell the exhaust gasses
Trying to smell the gases will be difficult and not tease safe, having your face over a hot coolant reservoir isn't the best thing and of you burnt yourself you would of bought the £43 tester 50 times over compared to a burnt face. The smell of coolant can be quite strong so trying to get a distinctive smell of exhaust gases maybe hard.
Discussion Starter · #20 ·
Ok so thanks for the reply’s I have done this and it has turned yellow not sure what I should do now car also overheated a week before doing this so I am not sure if this could have anything to do which it what should I do
1 - 20 of 21 Posts
