Hi, need a little help!! my partners astra G has intermitantly started to show the battery light & loseing power steering! This happend to me about two years ago when i owned the car so i took it to the local garage who found the alternater to be fualty so it was changed and all was fine.
Now the same issue is starting again so my first thought was the alternator so i have been out with the volt meter & tested for the telltail sign of a voltage drop when engine is running and headlights turned on but no significant drop only about 0.1v so i removed the + & repeated the test with battery out of the equation but still no real drop in voltage (again only 0.1v) altough without the battery conected the headlights did flicker a bit.
The only thing is that the fault is intermitant so it could be considered an unfair test as the fault was not presant while i was testing!
Any help please
Any help please
