hello and thank you for any advice passed my way.i have an x plate astra 1.8 sxi and it will not start when cold it has 2 be bunk started
in the two weeks i have had it it has started from cold 3 times. iv been told it mite be the idle speed controle valve wich i think is on the throttle body or the engine coolant temperature sensor. if anyone knows the solution to my problem i would be most grateful thank stu
