As title, I've gone through 3-4 resistors and they last the night, but next morning they're gone and I only have Full power for heat working (4).
I've read it could be the actual motor?
Is this a costly fix and could I get a 2nd hand motor from an Astra G?
Thanks in advance
Yeah it sounds very plausible for the motor to be gone. Just get one from another h. Just make sure you get either a normal air con one or climate whichever you have.
Mine popped the thermal fuse. I took the fan out, drilled a small hole in the bottom and lubricated the bearings with some ptfe spray and then spun it on my drill battery at full pelt for a few minutes
the resistor fuse I then bought a load off eBay for £5, crimped it on and it's been fine since
