Hi all! When the key is turned to ignition the headlights come on and stay one, turning the light switch doesn't do anything and because of this the heater lights/light switch module lights don't come on either.
Managed to get a code of B2657 Illumination Circuit Malfunction C-017 but don't know where to go from here, searched google and can't find any definitive fix, any help is appreciated, thank you.
Rhys
07 Plate Astra H Estate 1.7CDTI
P.S more codes that came up are U2201 CAN-Bus No Communication with EHU (Entertainment Head Unit) C-003, U2216 (Can't find anything for this). Not sure if these codes are related as they might be from a previous problem recently fixed.
what was the other problem
Thanks for the suggestions but I've fixed it now.
For others wondering all I did was pull the lighting module off whilst the car was off, pull the cable out put it back in and fitted the module back in place, turned the car on and it worked fine then!
must've just glitched out somehow
