Full kit to retrofit DAB to a MK5 Astra. Only suitable if you have a CDC40 fitted.
Includes:
This is the only way to get AUX-in on a CDC40.
Looking for £180 supply only or £210 fitted and programmed.
Includes:
- DAB module which is divorced ready to re-program
- Astra Mk5 aerial base and mast
- Aerial RF wire to run from aerial to DAB module
- DAB wiring connector and terminated cables. 2 canbus wires to display, power and earth
- Audio wires, via a change over switch which enables AUX-in go to radio. Has a 3.5mm jack lead for AUX. I mounted the switch in the tray by the accessory socket.
