1 - 20 of 45 Posts
My fuel display on the dash is way out, it is telling me I have about a extra 1/3 of a tank, but my range is right.
33411
I recon I have done something but no idea what I have done, and no idea to put it right,
I have done it while playing with opcom,
While I have been looking around to try and fix it, I have change some settings and nothing happend, so I put them back.
But I'm stuck to what I have done and no idea to get it back to normal
I don't think so,
I'm pretty sure I had to enter the correct thing, and a list of
001
002
003
Something like that, pretty sure I just picked the first one, but when I was programmin it took ages so I just pressed the back button, so I don't know if that was it.
Also when I tested the gauge,
33412
33413
33414
33415
You can see on the first test (second picture) the needle hasn't moved, then shoots half way, then full tank.
I’m waiting on my laptop coming back, would have to have a look at what mine does
I don't think so,
001
002
003
code index linear resistance 001, 1.8 non-vvt early model
2007 onwards fuel line fitted linear voltage type b, code index 005
Thank you, that now leads me to another problem,
I have changed my head unit from the cdc30 to the cdc40 opera, and I would of gone in the headunit page or informative or something,
Would this of changed the fuel gauge?
As there is a fault code with the headunit, not programed.
But the range is still spot on.
Head unit and display need coded as well bud, was just looking at the code indexes there myself
good website....if retrofit CC or sport button, AFL etc
i retrofit CC, GID and Sport button on mines astra
Sport button need more than just the coding, requires the ipc and a fair amount of thought, the 1 in my van still doesn’t work after 4 years
yes...i fitted the missing wires and turn it on, what it does change in throttle very response and sharpen the steering
firms suspension, turn off the TC
have you checked the missing wires behind the ipc and hazard switch?
to check for missing wires pin no.8 and pin no.17
what happen if you press it any light orange or?
1 - 20 of 45 Posts
