1 - 1 of 1 Posts
Hi, I`ve found the instructions for fitting the traction control switch but I have a problem. My car is a 2005 , 05 plate Astra Bertone Coupe with the Z18XE engine, on this car the ABS unit is different to the one shown in instructions. All the pins on the big connector are small pins except for two and all pins are wired, so the abs unit is obviousley different. Does any one know which is the correct pin to splice into for the traction control switch to work ? or the colour of the correct wire ? I know that the usual is pin 25 or 31 but these pins are not numbered and the plug is completely different. Any help would be greatly appreciated , cheers
1 - 1 of 1 Posts
