1 - 9 of 9 Posts
Hi
I have just got a sapphire black SXI and I really want to get a high gloss finish on it. normally I just wash my cars with shampoo then wax it. But I have notices some fine scratches on it and looking at the pictures of black Astra on the forum I would like to speand some time on mine getting it to look like these.
I have been given an electric car polisher but was wondering about what to use and how to do it. I have seen posts regarding Snow Foam, Clay and differant polishes and sealers but was wondering what you would recommend to a complete novice?
Phil
Do what I did on here, read up as much as you can on here about how you use clay etc and then start from there.
As for polishes/sealents etc everyone has their own favorites just look for the finish you'd like and price up the products that were used.
I will carry on reading the post here. Can anyone recomment a good place to get these things from?
first things first if you rlooking at using a polisher what one is it and have you used one before as a scrap panel might not be a bad idea.
do you need the whole kit or just bits as once its correected you need to know how to maintain the finish whilst minimal.
2 buckets - b&q
wash mitt/sponge (grout sponge or zymol sponge)- cleanyourcar.com
drying towel decent one- cleanyourcar.com
dodo lime prime by machine or hand - cleanyourcar.com
if by hand then Ag Super resin polish - halfrauds
chemical guys ez creme - cleanyourcar.com
dodo purple haze or if you can push to it dodo supernatural though now winters comin u might wana think about coli and leave the dodo till spring/summer- cleanyourcar.com
Hi Alan
All I have at the moment is some cheap shampoo, wax and a bucket. The sponge has been binned.
The polisher is a Halfords 240v
what I would like is a complete starters kit something easy to use but would give me the finnish I am looking for.
the main problem is scratches and swirls.
Phil
to be honest the polisher wont be able to remove defects such as swirls etc you would need a proper da or rotary for that,
whole kit would be
1.3 buckets 1 wheels 2 clear
2.wash mitt
3.drying towel
4.chemical guys shampoo
5.microfibres
6.sponge can be used on wheels or get a set of detailing brushes of ebay
7.window cleaner
8.hose/watering can open ended to sheet the water of the panels
9.clay (if claying its wash, clay, wash then dry which only needs to be done twice a year)
10.then Autoglym Super resin polish to mask swirls but ths will only do that no correction will be performed.
11.ez creme glaze 2 coats
12. sealant if preferred
13.wax of your choice 3 thin coats spaced 48 hours apart using foam aplicator pads
14. dodo red mist for top ups (dont use directly after laying a wax down
its a mixture of Halfrauds for Autoglym SRP and window cleaner, B&q for buckets and the rest from cleanyourcar.com
probably missed some bits but thats the main jist
whole kit would be
2.wash mitt
3.drying towel
5.microfibres
7.window cleaner
Hi Alan
what polisher would you recommend? I can get the other bits and pieces over the coming weeks but the polisher I'm not sure about.
Phil
Thanks for the links. just need to read up about techniques now(Y)
1 - 9 of 9 Posts
