Hi Guys
I have a bit of an odd issue in that every time I take my Astra over 70ish mph I can feel air coming through the vents as if I'd turned the fan on.
The fan is definitely set to off but I can alter the temperature of the air coming out using the temperature dial as if the fan was on as normal.
Has anyone else experienced this and is there a quick/easy fix ?
Its normal, the airflow circulates no matter if the fans on or not, if you stop driving the airflow will stop as well
This, there's no external shut off for air coming into the cabin short of closing all the vents, so you get the air being forced through the heater matrix via the speed of the car, the fans in effect are just there to help it along.
AON - Administrator
As the gentleman above have said ^^
It was like a brace new world when I got my first Audi that seals the outside off
