1 - 7 of 7 Posts
This will plug into your existing loom and give you full Bluetooth like the factory kit, it just needs to be fitted and programmed to your car. £200
Lee
This is probably a stupid question, but is the factory kit capable of? Can it play music or is it just for calls? And will it only work with certain stereos?
Just for calls but very very good at it. Can access your phonebook all from the steering wheel controls. Can also use voice activation for calling!
It is a good piece of kit just remember though that you must have either a colour info display or a graphic info display for it to work
will you do the fitting and programming?
1 - 7 of 7 Posts
