1 - 9 of 9 Posts
Anyone done this? I recently have but i have an issue with the rear mount bracket fouling and causing vibrations. Now i am wondering if the rear mount bracket from a mk5 1.7 cdti with f23 will cure my problem? I know there is slight difference between g and h set up dispite their similarities so wondering if this will work as although bracket looks the same it has a different part number ? gunna have to buy it to find out aint i? ?
Yes mate the success story at last ?
Much quieter on the motorway now and ypu can feel the boost curve more ow its less erratic through the gears ? diesel box is still in the pipe line if i keep the car
For all it’s weeknesses, the M32 is a good box, and fairly quiet at motorway speeds
Not in a highly strung 2.0 turbo ? screams its **** off all the time.. Ive got a vectra 1.9 sri cdti on an 08 which has an m32 and has been well behaved considering the abuse it gets on 185k atm too seems better on fuel all be it couple of mpg per gallon but every little helps says tesco ?
1 - 9 of 9 Posts
