1 - 16 of 16 Posts
My astra Mk5 55 plate on 72K miles won't start.
I think the starter motor has failed but it might be more than just a stater motor.
I got the following fault codes from a pedal test:
ECN 20100
ECN 20200
ECN 20300
ECN 20400
ECN 23002
ECN 65070
ECN 15505A
ECN 16003A
ECN 210300
ECN 210400
ECN 210870
ECN 213970
The engine management light was also flashing whilst the codes were being displayed.
I'm not sure what these codes mean and i'm struggline with my car as its been off road for a few weeks now :confused:
Cheers
Is the battery in good condition and fully charged? What makes you think the starter motor has gone? If it continually clicks whilst turning the key to the start position, thats the normal indication of a dead battery.
The battery may be weak after trying to crank it so much, it hasnt been changed since the car was bought but its more than just a battery issue
the starter motor makes this rattle and then makes a scream type of sound.
The key turns once and then it tries to crank then it gives up
after trying it, you turn the key again and tit wont even crank
P0201 Cylinder 1 Injector Circuit Low B-034
P0201 Cylinder 1 Injector Circuit Open B-034
P0201 Cylinder 1 Injector Short Circuit B-034
P0201 Cylinder 1 - Injector Circuit Malfunction B-034
P0202 Cylinder 2 Injector Circuit Low B-034
P0202 Cylinder 2 Injector Circuit Open B-034
P0202 Cylinder 2 Injector Short Circuit B-034
P0202 Cylinder 2 - Injector Circuit Malfunction B-034
P0203 Cylinder 3 Injector Circuit Low B-034
P0203 Cylinder 3 Injector Short Circuit B-034
P0203 Cylinder 3 Injector Circuit Open B-034
P0203 Cylinder 3 - Injector Circuit Malfunction B-034
P0204 Cylinder 4 Injector Circuit Low B-034
P0204 Cylinder 4 Injector Short Circuit B-034
P0204 Cylinder 4 Injector Circuit Open B-034
P0230 Fuel Pump Primary Circuit High C-004
P0230 Fuel Pump Primary Circuit Low B-027
P0230 Fuel Pump Primary Circuit Open B-027
P0230 Fuel Pump Circuit High Temperature C-004
U2139 CAN-Bus No Communication with CIM (Steering Column Module) C-003
look for this lot on the list
ECN 15505A
ECN 16003A
ECN 210300
ECN 210400
ECN 210870
ECN 213970
and make sure the battery is good and there is plenty of fuel in the tank, pref more than 1/4
Got more than half a tank of fuel, seriously don't know what's wrong so i'm gonna get vauxhall to diagnose the car on monday hopefully,
Strange my car did exactly the same last week and still with VX for repair. I would get your stater motor, alternator, thrttle sensor and throttle body checked. Also check all fuses.
Yeah the ABS light flashes and the engine management is always stuck on.. the car will not crank and i'm having to find a towing company to take the car to Vx which is costing me a bomb.
Fuses are all fine, checked all under hood and in the boot
Do the headlights go dim when you try to crank the engine over? If they do, then it is almost certainly a battery problem. Much cheaper to try and sort that yourself, than get the car towed to Vx and have them diagnose it!
i have 2005 astra elegance twinport and my car's ecn codes are same H-2-K'S Car so we have same problems do anyone know how it is concluded?What is the solution of this problem???
Mine had a dead battery last week. The instrument kept flashing; CID turning on and off. Turning the key just kept getting a clicking noise. RAC came out tested the alternator which was providing plenty of power but the battery just wouldn't hold charge. He did say that modern battery's just go without any warning.
Was there ever a resolution to this issue? I've just replaced my EGR valve and the issue is still present, thankfully the EGR fault codes have gone now.
Many thanks
B
ECN 20100
ECN 20200
ECN 20300
ECN 20400
ECN 23002
ECN 65070
ECN 15505A
ECN 16003A
ECN 210300
ECN 210400
ECN 210870
ECN 213970
Cheers
Did you ever resolve this H2K?
1 - 16 of 16 Posts
