1 - 7 of 7 Posts
Hi just brought a Astra 1.4 turbo on a 12 plate 140 Bhp engine EML just came on car drives fine what are the common faults on these models what symptoms would I get if the ecu what knackered any ideas.
Fault code read it first,absolutely no point in guessing what may be the problem
Computer Font Personal computer Display device Electronic device
My mechanic plugged in his reader and all their come up he said it could be the coil pack .
deleted comment. I didn't see the fault codes posted initially.
DTC P1101 Intake Air Flow System Performance
Conditions for Setting the DTC
The ECM detects that the actual airflow rate is greater than the calculated airflow.
It could be a lot of things,other than checking the integrity of the inlet system/air filter/vacuum leaks etc
you'll need a scan tool that's capable of looking at the live data on the MAP/BARO/BOOST etc.
1 - 7 of 7 Posts
