1 - 8 of 8 Posts
Right my problem is this, while driving around ive noticed my handbrake light coming on ever when the handbrake is fully down, it will stay on for a while then go off.
Does anyone know what might be causing this?????
sticky switch ???
try some electrical contact cleaner on the switch
could also be problem with fluid level switch in the reservoir?id check for pad thickness(front+rear)then check for leaks,top her up if required,then moniter carefully.
ok guys thanks for the advice im going to top it up in morning and have a check off the pads coz its on most off the time now
Right had alook at this today and found out that my brake fuild was indead low and the cap was lose, so i topped it up and tightned the cap and touch wood its all fne now
Thanks for the great help and advice as always people :thumbs:
1 - 8 of 8 Posts
