Hi all
Like many, I've taken the EGR valve off my 1.9CDTi 150 to clean it out. Was very badly gunked up - the worse I've seen and I've done this a few times on a few cars.
After putting everything back together though, the EML was on. Pedal test brought back ECN 040004 and my scanner says it's EGR. There was no fault or EML before and it clears once but comes back as pending so next time the car is switched on, it comes back.
I've checked everything is tight, gaskets are on, and the valve moved fine after cleaning. Electrical connector is in correctly too. Any ideas? I've found a few threads like this but they don't seem to have an answer as to the resolution.
