They're just stuck on with glue, so there will be no holes left. I personally use hot/warm water, my old MIGweb membership card (because I have no use for it otherwise :p), and some white spirit.
The warm water helps to soften the glue. I then gently slide the card under the badges and prise them off. Once off, there will just be a bit of glue left on the car. The warm water and the white spirit helps to soften and remove the glue from the car. I've never found the white spirit to cause any problems with the paint work.
I've also heard some tar removal products are also quite good at removing the glue if you are not comfortable using white spirit.
The results:
A.O.N. - Platinum Member
SEARCH is your friend biuddy. There are huindreds of threads on this
