1 - 20 of 578 Posts
This is my 1.7 cdti
Spec so far
Vxr clocks
Leather wheel( courtesy of golspie)
Eibach sport and bilstien B4s
Rear seat
Full estate rear end
Full headliner with roof mounted tweeters
Poineer double din with bluetooth
Blue smd conversion
Full leather interior
Auto dim rear view
Roof console
Extra roof lights irmscher pedals
Armster armrest
Rear antiroll bar( adjustable, 3rd hole)
24mm front arb still to go on
Fogs fitted
Xenon headlights
Sri 3 door bumper in for paint
Vxr grille in for paint
Everything to fit headlight washers
Alloys twintops in anthracite with matching centres 215/45/17(again golspie)
Thats about all i can remember
Forgot, powerflex black rear axle bushes
Sump guard to be fitted
Sports button( lights up when pressed, does hee haw else)
Alpine speakers, front and back,
Centre dash speaker
Drilled/grooved rear discs
Still got some other stuff to do/ get done/ probably done lol
Super Moderator
So, I'll need to dig out the parts I have from the estate but I think I have all the hooks etc.
Might get round to this sometime soon, need to find a welder first :lol:
I got 1 on gumtree, charges me £60, tho i had already taken an angle grinder and spotweld remover to the floor , guy was from falkirk iirc
Sent from my iPad using Tapatalk
Discussion Starter #12
Yep, more or less to the front of the wheel arch, guy came and welded it at the house
Discussion Starter #13
Just have to work out how im going to mount the rear door cards, and drop the speakers down behind them, got a few ideas but open to suggestions
Discussion Starter #15
Iv got the cards, reckon some plywood and some 1/2 inch blocks of wood, be able to screw the cars on in the normal places, and a few extra around the sides, thinking that if i get rear door seals and put them the wrong side, ie the comprssed roll side in, probably stop a lot of rattles, then foam pad the tops with grey nylon covering, should do it
You could get a donor set of rear doors and cut the inside panel off and weld that in place, gives you something to mount the door cards to as well as the speakers?
1 - 20 of 578 Posts
