1 - 20 of 177 Posts
I've just realised there isn't a sticky thread in this section for the common problems etc of the astra G... So with this in mind, I thought it would help other people out if you could all post up problems in here - that you know for a fact are pretty common, not just any so and so problem!!
Maybe separate them into sections for example (I don't know all the engine codes so...):
GENERAL
Rear springs tend to break
PETROL ENGINES
Cambelt driven engines - water pump should be replaced at service intervals with cambelt
Z20LET
Air Flow Meters fail occasionally
Z18XE
DIESEL ENGINES
Please make this constructive as possible!!! :thumbs: :thumbs:
I think it's a great idea and I'm surprised it hasn't been done before!
The rear springs do tend to snap, but the lowered springs (SRi and GSi models) are an exception to this rule.
Also, rear disc brakes on the SRi models have a tendancy to seize up if they are Bosch calipers (Lucas calipers replaced the Bosch ones and solved the problem).
Can't think of anything else just yet.
GENERAL
+Rear springs tend to break
+Rear disc brakes on the SRi models have a tendancy to seize up if they are Bosch calipers (Solution - replace with Lucas calipers).
PETROL ENGINES
Z20LET
Z18XE
DIESEL ENGINES
DIESEL ENGINES
1.7DTi:
Turbos and head gasket issues around 80-100k.
ECU sometimes burn out
Glow plugs fail leading to EML and obvious starting problems
2.0DTi:
Injection pumps fail at 60-80k if using crappy diesel (see Adsa/Morrisons, Tesco). £800 for a recon unit including fitting!
Turbos are weak, can fail at 80k
Injector seals can leak leading to starting issues
Injector spill pipes perish, also leading to starting issues
EGR problems due to clogging with soot
GENERAL
PETROL ENGINES
+Cambelt driven engines - water pump should be replaced at service intervals with cambelt
Z20LET
+Air Flow Meters fail occasionally
Z18XE
DIESEL ENGINES
1.7DTi:
+Turbos and head gasket issues around 80-100k.
+ECU sometimes burn out
+Glow plugs fail leading to EML and obvious starting problems
2.0DTi:
+Injection pumps fail at 60-80k if using crappy diesel (see Adsa/Morrisons/Tesco). £800 for a recon unit including fitting!
+Turbos are weak, can fail at 80k
+Injector seals can leak leading to starting issues
+Injector spill pipes perish, also leading to starting issues
+EGR problems due to clogging with soot
Thanks ZS :thumbs:
Pre 2003 2.2i
I read somewhere that the oil outlet for the timing chain is too small, and can become blocked - causing a snapped timing chain, and a much lighter wallet.
However, this isn't mentioned on Autodata, so I don't know. Anyone have an idea? My mechanic friend recommended that when you have the oil changed, flush it through with a load of cleaning gunk, just to be sure (Y)
Discussion Starter #12
GENERAL
+Anti-roll bar bushes dry out and you get creaking sound over large bumps
PETROL ENGINES
Z20LET
DIESEL ENGINES
1.7DTi:
2.0DTi:
@Mikehodges I'm just waiting to hear confirmation of what you said before putting it in. I personally have no idea if it is true or not!
Rear Bosch caliper seizure applies to all 1.8 16v/2.0Di 16v with ABS and all 2.0DTi 16v/2.0 16v as all these get the 264mm diameter rear disks, not just SRi.
Pre 2003 2.2i
this is true but most the engines with this trouble went into the vectra! only a couple of the early 2.2 astra's had this fault but u dont see them anymore
Discussion Starter #16
GENERAL
+Rear disk brake seizure, Rear Bosch caliper seizure applies to all 1.8 16v/2.0Di 16v with ABS and all 2.0DTi 16v/2.0 16v as all these get the 264mm diameter rear disks (Solution - replace with Lucas calipers)
PETROL ENGINES
2.2
+Oil outlet for the timing chain is too small, and can become blocked = snapped chain! (Solution - At oil changes flush and clean it, Early models only)
Z20LET
DIESEL ENGINES
1.7DTi:
2.0DTi:
Coming on good people, I'm sure there's more that can be added! Keep 'em coming :thumbs:
on the astra z18xe and the 1.6 8v the ticking noise coming from the engine cambelt area on start up (not carbon canister) seems to be a common one seen a thread on that one a few times.
I have had faults with my alarm in the past where the power sounder had to be replaced two or three times. Good idea for a thread.
Yeah i've found a ticking sound from the engine from cold. I'm starting to get really picky about things.....or should i???
1 - 20 of 177 Posts
