I have been unable to find a post with a clear understanding of this problem and it's solution. Basically I have fitted a set of TA Tecknix coilovers on my mk4 astra. I have even changed the droplinks to adjustable a and fitted a pair of camber bolts. The problem I have is with the top mounts, I have been through several forums and only one made sense which was to build the coilover just like a standard strut eg spring cup, tapped the bearing out and fitted it on the coilover then the rubber mount ontop of that with the metal plate ontop of the sub frame. Yet there is still a massive gap between the sub frame and the metal plate on top. I just don't understand where this gap has come from and how to get rid of it.
Any suggestions?
