2007 Vauxhall Astra 1.9ctdi
Hi guys I'm new an know nothing about cars on way home from work my car made a sound which I thought was like a flat tyre but ended up in car stopping an not being able to turn over my friend had a cheap code reader which he put into car which sent these codes P2279,PO400 ,PO660 any idea y all 3 would come at once an I'm still awaiting on my mechanic to look at it
It's a 2007 astra 1.9cdti any help would be appreciated so as I have a rough idea as to what mechanic will be telling me
P2279 Intake Air System Leak Detected
P0400 01 Exhaust Gas Recirculation (plus lots of subcodes)
P0660 01 Swirl Level Control Solenoid Valve (plus lots of subcodes)
nothing there that will stop it cranking
Cheers for ur reply cud the battery have just died in the process to add insult to injury
Are those code problems fixable? Sorry but I know nothing about cars an rely on this car to get to an from work
The codes are fixable and probably related to each other,
if you suspect the battery then you'll need to get it a new one or get the old one charged up and see if it'll crank
