My 2016 Astra was recalled and the clutch problems supposedly fixed however I’ve started having the same problem again. I have taken it to my local dealer and the initial diagnostics have not identified the cause so further investigations are required. This involves removal of the gearbox etc and if it isn’t linked to the recall they are going to charge me £750 to diagnose the problem! Has anyone else had further problems with the clutch sticking after the recall repair?
Is the car not still under warranty? Unless you have done huge mileage since they 'repaired' the clutch, I can't see why you should have pay for it to be repaired again if this issue is the same.
Ridiculous. Avoid paying that in any way you can. It's clear that if the problem persists after the recall, then the job wasn;t done properly in the first place
