Hi i have the gtc 1.6 turbo 15 plate.
im having a problem with the clutch pedal sticking halfway down when i take my foot of it.
i put my foot underneath a couple of times to move up and operates normally after.
only happens once or twice when im driving, sometimes not at all.
everything else is fine.anyone got an idea whats going on ?.
I had a problem similar to yours mine 2010 plate Astra j clutch peddle when pressed would sometimes stay half way down and would have to use my foot to pull back up would happen every now and then it turned out to be clutch master cylinder was on its way out replaced never had the problem since
Remember it being around the £220 mark as had a engine mount bolt replaced as well and it was threaded but was same issues as yours only every now and then clutch wouldn’t return to same position and when it did was slow to return think it was leaking was over a year ago had it done
