1 - 14 of 14 Posts
Weird clicking noise coming from my engine when I'm driving and when I stop it continues for a second then seems to disappear.
Timing belt issue ?
How loud? Is it constant? Is it rhythmic or does it change? When you say it continues after you stop do you mean stop driving or actually turn the ignition off?
Not really loud but enough to hear without radio on. Stops completely when engine is off and can hear it when engine is turned on for 2 seconds then disappears.
Could be the air con compressor.
My sport hatch used to make a click on / off noise.
Try turning the air con off and see if it still does it .
Discussion Starter · #7 ·
It's when I let go of the accelerator you hear the noise it's kind of like a gurgly noise. Coolant level is normal as is oil level.
1 - 14 of 14 Posts
