1 - 20 of 31 Posts
Hi All,
I am probably the only Vauxhall Astra J owner that managed to crash his car in less than a week of owning it..
Automotive parking light Car Vehicle Automotive lighting Grille
Cosmetic damage only..I will need to replace the Front Bumper/Grill/Headlights. Everything else seems to be in working condition.
However, I am struggling to find the exact bumper. I would prefer it to be new and paint it myself. Could someone help me identify what exactly I need as I am only finding this model, which certainly won't work:
Automotive lighting Hood Vehicle Automotive design Grille
Many thanks in advance.
Discussion Starter · #2 ·
Oh, I also found one hanging wire. As all the lights are in working condition, I was wondering what this could be
Automotive tire Hood Automotive lighting Tire Tread
The "wire" is the outside temp sensor,
if you want help with part numbers then we need more car details,reg or vin should do
According to the vin your car has the OPC / VXR LINE PACK 2 fitted from the factory
so different from most out there
Bumper panel 13462766
lower grille 13401084
n/s headlight 13365292
Discussion Starter · #7 ·
This is what makes it so confusing..most of the websites will not match the right parts. I will get around it in time, as I said, I only bought it 1 week ago.
Automotive lighting Automotive parking light Drinkware Rectangle Font
Discussion Starter · #8 ·
Could I ask you what n/s comes from? I've also seen some items listed with n/s/f and I am not sure what it means.
Thank you in advance.
Regards,
Stefan
n/s = nearside (lefthand on rhd car) n/s/f = nearside front, n/s/r = nearside rear etc etc
o/s = off side (righthand on rhd car)
Discussion Starter · #12 ·
I know..I'm such a dumb ass. I'm dissapointed with myself as I'm not usually like this..but I guess **** happens and I hope my bad luck depleted with this event.
Another question if I may. With the whole emerging from the crash, I noticed where my coolant is leaking from. I believe this is a pre-existing issue that I bought the car with.
Water Wood Flooring Floor Material property
Would anyone recommend something like this? Would it even fit well and all? It's either this or other aftermarket alternatives that have plastic sides, like the following:
Font Gas Rectangle Technology Machine
The original part is excesively expensive and I would avoid that if I can.
Regards,
Stefan
You'll struggle to find a used bumper for your car as your spec is rare.. or youll pay a silly price for a used one.
get a new primed one it should only require paint
start of my asking vauxhall as sometimes main dealer is cheaper than third parties
Here are used ones:
Discussion Starter · #15 ·
Thanks mocool. I've seen those on ebay but they are broken and repaired. The Vauxhall genuine ones are more than £1000 and I am not even sure it comes sprayed in the right colour. I will keep looking
Theres one in wales in white
or black in sheffield with a bit of damage a bodyshop can repair
Discussion Starter · #19 ·
yeah, I'll have to repair this one myself. thanks for sharing the links and all
1 - 20 of 31 Posts
