1 - 8 of 8 Posts
Hi Guys,
Does anyone know what sensor this is:
The connector itself isn't connected and is just hanging loose. Recently the car was running slowly and very hesitant when trying to pick up speed. We put the computer on the machine which revealed a faulty Coil Pack, we replaced this with a used one which got rid of the engine light but the car is better but doesn't seem normal. I have serviced the car as well after this but it's still the same.
Many Thanks,
Ahh thanks mate, so should attach to were Liam advised, does anyone know what the actual job of this sensor is or whether it being disconnected makes a difference to anything.
if you disconnect it, id imagine something would go open circuit and not work at all, its to remove electrical noise, probably from the ignition system
1 - 8 of 8 Posts
