Hi everyone , need some help with a Astra h 1.8 petrol. Seems to have a oil leak from cam shaft sensor so I’ve been told. Before I replace it wondered if any of you guys can shed a bit more light on it. Here’s some pics of it very oily all around but just want to make sure and also which part do i get ?
33329
It's a job to see exactly where the leak is but there is a seal that goes round the cam sensor,
the sensor is only held in with a single bolt so easy enough to remove it and check exactly where it's leaking from.
There is an o-ring listed,to get genuine you'll probably need to order it through a dealer or one of the online genuine parts suppliers,alternatively pull the sensor out and see if a local garage or motor factor can match it up.
Ah right thank a lot , having trouble matching it online , I have taken it out and can’t find a matching one
