Because ive got heavily tinted rears and need the brighter light to shine throughWhy would you want brighter lights? More power for a fixed voltage means more current, which squares to give even more heat, which melts the lamp, or the wires :shrug:
These lights are garbage. They arent even the SRI ones. I just would like to know which LED's are brighter than the others? A normal light bulb for a domestic appliance has the wattage on it. A fluorescent light will be marked with the 'lumen' rating which determines its brightness. There is also a code for LED's which tells of their brightness, i just dont understand the various codes applicable to each LED and i just would like someone who is in the know to tell me which canbus LED's are the brightest?You can get 8w LED canbus rear bulbs at £27 a pair but there no brighter than a standard bulb, nor E-Marked for UK use.
These would work.
http://www.ebay.co.uk/itm/VAUXHALL-...ts_Vehicles_CarParts_SM&hash=item3368847292&_
Thing is.....the law doesnt actually say you have to display clear rear lenses. It does say you have to display rear red lights at night, red braking lights, amber indicator lights and white reversing lights. You can have dark lenses as long as sufficient light shines through.I would worry about the reflector when your lights are off, thats what mr plod will pick up on.
Got ya! So a brake light would be better with 30 degrees as its seen directly from the rear, wheras an indicator would be better with 120 degrees as its seen from the back and the side. Im going to have a look now at those codes youve given me. Cheers matey!LEDs are often quoted in Lumens and Candela "CCD", the higher the brighter, to confude matters they are also sometimes quited as x Watt equivalent.
I would suggest that, if no-one comes back and says, "these brand x lamps are excellent", then purchase a set and trial them.
the bigger the number the higher the O/P
Please bear in mind if it's a single LED there is a viewing angle too, so a 30 degree lamp of the same O/P power lamp at 120 degrees will "look" brighter straight on but will be poor from off straight.
Halfords one are!Are they canbus friendly? I cant be doing with the display giving me grief![]()
Cheers mateyHalfords one are!
brakes, sides and rear fogs I replaced!!
On our lasses G cabby Turbo too!
front sides are 13 smd canbus compatibles!!
In WHERE?A guy on another thread has sent me a link to some canbus LED's in King Dong, which state they are twice as bright as normal bulbs. At £6 for the pair inc post i may give them a try :look:
You need Stampede!!!Yeah i think im getting the gist of it. Problem is, how do i know the correct resistance to administer to each LED? I wouldnt be confident tackling this myself on the car in case it goes wrong and im left with wiring probs...............and a car electrician would probably be pricier than the pricey canbus LED's in the first place?![]()
