1 - 7 of 7 Posts
Do I need to buy some when changing the pads? Didn't even know they were that technical!
How will I check?
NO!, if you have them the same ones will do unless damaged of course.
I personally do not use them and I remove the squeal/contact clips. Who does not know the condition of their own brakes, EH?
When you were painting your front calipers, did you see a wire conected to them?
Nah! But wasn't paying much attention.
Just masked off and went for it.
i dont think many were fitted with sensors, and there will be an additional cable for the sensor, one is abs, then the brake hose, then the sensor is separate.
1 - 7 of 7 Posts
