Just to let you know, I complained to the dealer about the fuel sloshing in tank when full, they have now put it baffles in the tank to prevent this on warranty.
Other issues with water leak in boot now fixed, some wire was trapped under seal in the light housing which left a gap and damaged the seal, they now replaced the light housing and seal. Still need to test if this has indeed fixed it.
They checked high fuel consumption again and said there is nothing they can do as it falls in correct parameter so will have to live with that.
Also, checked if they were any software updates but nothing was done.
