Hi all,
A couple of quick turkey noise questions...
1. When this happens, is it louder than the normal little 'chuff' you get when the standard DV.
2. If this isn't caused by the 'popped off' pipe on the vacuum box, is the split diaphram the only other cause?
I mainly ask as I am not too sure whether I have a problem or not on my VXR.
When changing gear, sometimes it sounds like a cross between the turkey gobble and a standard dump. IE a standard chuff but stuttered (if that sounds right). The car also seems to be popping and banging from the exhaust loads more than previously and fuel economy seems to be worse (although I'm not 100% on the economy, I don't look too closely at that!)
I've checked the vacuum pipe for wear/popping off/etc. and it's all good.
Ta in advance,
Graham.
Ta in advance,
Graham.
