1 - 2 of 2 Posts
My Astra VXR only made 215 on the Dyno and by looking at the graph, it looks like it's being held back around the 3500 range.
The car only has a pre-cat delete, Cobra cat back system and a crossover delete with AEM cone.
The standard bhp is 236bhp but mine is only peaking at 215bhp
The standard Torque in NM is 320 but mine is up at 376.
I find it odd that the torque is up but bhp is down.
I've done the following:
  • Checked the actuator is opening at 10psi
  • Smoke test carried out - no boost leaks
  • Replaced Map sensor
  • Cleaned MAF
  • Replaced front Boost Solenoid
  • Checked all vac pipes and ensured all pipes connected at the rear of the vac box
  • Replaced coilpack
I've been trying to figure this out for a while, I did notice after changing the coilpack the car is running better and a slight improvement in the car being more aggressive as it was when I got it.
I've tried to narrow it down as much as I can but is there anything else anyone can maybe advise me on?
Also, the code 110611 popped up after the Dyno, reason being why I replaced the MAP sensor but after clearing the codes the code hasn't come back.
Thanks all
1 - 2 of 2 Posts
